Home > Maintenance & Mods (L322) > Td6 viscous fan removal..
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
Had my Td6 a few weeks now and overall am really pleased with it, other than the damm amount of noise it makes, when pulling away or accelerating it sounds really loud and almost like its slipping. I'm thinking it is probably the viscous fan, does removing this quieten the td6 down alot? Are there any other measures I can take to make it as quiet as possible (buying a tdv8 doesn't count) haha
Post #297243 5th Dec 2014 8:12pm
Does your aircon work? If so, remove the viscous for the winter... The aircon fan works when the temps go up BUT... ONLY if the aircon works Thumbs Up
Kingpleb has his removed i believe...
Post #297264 5th Dec 2014 10:31pm
mjdronfield
Has it got a performance air filter? If so, there is quite a bit more induction noise when accelerating.
Worth a check....
I wonder if you can fit more sound deadening under the bonnet ?
Don't think the fan is that noisy on mine. Only when it stays engaged occasionally. Had a new one under warranty. Not as bad. At staying engaged - new one same noise level when engaged....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #297286 6th Dec 2014 5:25am
JPS
Hi guys, yes my air con works a treat and leave that on all the time. Im sure it must be the viscous fan making most of the racket i think next week i will have a go at getting it off and then see if its any better without, will perhaps do a coolant change and flush at the same time so that i know its done then.
The air filter is just a standard one as i just replaced it myself a couple of weeks back, good idea on the sound deadening and on the bulk head also might help a bit possibly.
Post #297301 6th Dec 2014 9:05am
If it sounds like a small airplane engine then the viscous fan has likely locked up as the unit fails.
I and a few others have our fans removed on the TD6 and you could likely get away with on the tdv8's as well. They really are for countries that don't ever drop below about 10-15c at their coldest. Even when it gets hot here the electric fan can move more than enough air and works when the engine is off as well. When they are at full speed it's as load if not louder than the viscous fan and does its job well. Just leave the ac on all the time and enjoy fresher cleaner air(replace the filter every 6-12 months though!) and be done with it. It saps power and economy although I haven't noticed much improvement with it off from before it failed.
You can get replacement viscous units so keep and reuse the fan itself but they still are about £130-160 iirc. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #297416 7th Dec 2014 12:41am
JPS
Cheers buddy, I have some fan spanners so will whip it off at the weekend and see if it is knackered or not. Thumbs Up
Post #298212 10th Dec 2014 5:46pm
Naki
United Kingdom 2003 Range Rover Vogue Td6 Java Black
I recently purchased a 03 TD6. I have realised a previous owner had already removed the Viscous Fan on mine.
It runs fine, currently, but it is the middle of winter. I am only doing rural short journeys.
I have not specifically tested the air conditioning yet, so I don’t know if the electric fan works yet.
How many members out there in the U.K., permanently runs TD6 without the Viscous fan?
Post #582363 4th Feb 2021 2:59pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
I had owned my old 4.4 V8 petrol for a few years before I realised that the viscous fan had been removed by a previous owner Rolling Eyes
I took it from 49000 miles to 147000 without one. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #582377 4th Feb 2021 5:06pm
Naki
Interesting. If anything I would think a petrol V8 would need one more than anything?
Did you use it all the year round including hot summer days 25-30c? Sat in traffic jams? Towing?
All the possible hardest situations for a cooling system.
I will likely do some towing at some point. 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
2003 L322 TD6 Vogue with Facelift conversion
2000 Discovery 2 TD5 ES. Daily
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #582378 4th Feb 2021 5:11pm
chris_read
Yes, all year round for 9 years with no issues as a result. Very little towing until the last couple of years when it pulled an Ifor horse trailer a couple of dozen times but still didn’t throw up any problems. Perhaps I was just lucky Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #582390 4th Feb 2021 6:15pm
Naki
Ok, that’s good to hear.
Was that towing in winter or summer? 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #582392 4th Feb 2021 6:25pm
chris_read
A bit of both winter and summer but mainly good weather. In the time I had the cari don’t think the temperature gauge moved any higher then the middle point. As I said, I may have been very lucky so don’t take it as a recommendation as the fan is there for a reason - it just wasn’t on my car Laughing 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #582393 4th Feb 2021 6:29pm
Naki
I was wondering how common it was that people removed them. I guess the fact there’s forum posts on if, relatively common?
I thought mine got up to running temp very quickly for a diesel. My TD5 disco takes 4x longer to get to temp. 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
1990 RRC 3.9 V8 LPG
Too many Jaguars!
Post #582397 4th Feb 2021 7:29pm
