Home > Technical (L322) > removing wheels(suspension position)
rover1
Im hoping to change my front discs and pads this week.
Which suspension mode should i do this in?
Also, whats the best jacking point and should i raise both wheels up at the same time?
thanks
Post #297788 8th Dec 2014 8:09pm
rover1
sorry, should have said L322 tdv8 3.6
Post #297790 8th Dec 2014 8:20pm
leave it in standard and jack up on the side jacking points or the cross members underneath...jack one side at a time and use axle stands....when you take the FF off the axle stands you might have to toggle the suspension so it settles into its setting.. ... - .- -.
Post #297792 8th Dec 2014 8:24pm
If your jacking the front up at home on the drive? I would stick it in off road height and importantly leave the door ajar which will inhibit the air suspension from trying to self level whilst you jack up one corner, potentially unsettling the car whilst on a jack sir Thumbs Up
Then as Stan said, use stands etc Thumbs Up
Post #297822 8th Dec 2014 10:17pm
rover1
cheers guys i will jack in off road mode.
Post #297928 9th Dec 2014 2:51pm
