![]() | Home > Maintenance & Mods (L322) > Not sure my driver's Heated/Ventilated Seat is working |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 ![]() ![]() ![]() |
Got the same idea, coming from a "normal" seat heating. I just think that the electrical seat heaters have a shorter response time. You feel them quicker warming up. But I stand corrected... |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
Can only give info from my experience in my p38 which has heater element the heat is there almost immediately but with my FF it can take a good 5 mins for heat to come through - so if I use the heated seat on a short journey the fans run but no real heat hope this helps |
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 ![]() ![]() ![]() |
Thanks for the replies.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
is it not the case that the heating in the climatic seats is warm air and not electric element? cold engine means cold seat?
Its a peltier unit under the seat that gives the temp difference there is a slight delay in the heat getting through maybe 3 minsish |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
My car has suffered the same fate for the past 18 months |
