Home > Maintenance & Mods (L322) > Tyres - which wear first? front or back? |
DeltaC Member Since: 22 Mar 2010 Location: Aberdeenshire Posts: 148 |
I wear my front ones a lot quicker than the back despite it being a four wheel drive.. I tend to find the corners and roundabouts seem to remove most rubber |
7th Jul 2010 5:17pm |
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 |
Passenger front wear quickest generally |
7th Jul 2010 6:39pm |
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 |
As suspected, Thanks.
7th Jul 2010 7:23pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
What's peoples thoughts on this? Leave the NSF tyre on (and take the wear) therefore saving other tyres, or rotate wheels, to even out wear?
28th Sep 2010 7:55am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35270 |
easiest way is to jack one side front up, stick a axle stand under there then jack up the same side rear..do one side then the other,,btw dont try and use the supplied scissor jack, its pants..use a trolley jack. ... - .- -. Y. O. L. O. . |
28th Sep 2010 8:00am |
firstly i would be tempted to have a four-wheel alignment check done to make sure the its ok...you could turn on the rim so that the worn edge runs out on the other side ,it all depends how bad it is .. ... - .- -. Y. O. L. O. . |
28th Sep 2010 8:03am |
2-3mm over 7K of motoring (on the one edge). It's not to bad, just noticeable |
28th Sep 2010 8:40am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
mine always seem to wear out all at once whether they are Michelin Goodyear or Vreds - not many roundabouts or city driving where I go though... |
28th Sep 2010 9:17am |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 |
this one wears the right front first i guess
28th Sep 2010 6:03pm |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
At least that one is not on craptinentals otherwise it would wear the shoulders off both fronts even like that 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
28th Sep 2010 7:03pm |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
28th Sep 2010 7:07pm |
Interestingly I just had some tyres changed to different rims, the tyre fitter put the tyres back on, with the more warn side on the inside of the rim.
29th Sep 2010 1:33pm |
Nice idea Richcl - but not only are the Craptinentals that Tim referred directional - the outside edge is indicated on each tyre (Pattern of manufacturers script, Tyre size etc. is different on the inside/outside wall). |
29th Sep 2010 1:40pm |
Oh yes, didn't think of directional (My tyres are uni directional) |
29th Sep 2010 1:43pm |
