Home > Maintenance & Mods (L322) > Door Handle Covers
Paul_H
England 2005 Range Rover Vogue Td6 Tonga Green
Door Handle Covers
Can anyone teall me if the door handle covers that are colour coded for a RRSport will fit my FF as I have been looking for Tonga Green ones and can only find them for a sport or a D3 Crying or Very sad 2005 Range Rover Vogue with Supercharged Accessories
GONE 2001 Discovery TD5 ES
GONE 1995 Discovery 300 tdi GS
Post #295859 29th Nov 2014 11:55am
Different shape handles Thumbs Up
Post #295871 29th Nov 2014 12:43pm
miggit
I put a set of these on mine, not as shiny in yer face as the abs chrome, and made of solid Stainless steel, so you polish out scratches and there's no paint to ware off Thumbs Up
http://www.ebay.co.uk/itm/RANGE-ROVER-Chro...3a9b931d6a Yesterday I couldn't spell Engineer... Today I are one!
Post #296002 30th Nov 2014 12:25am
Paul_H
Thanks miggit, I've just ordered a set, any tips on fitting them 😉 2005 Range Rover Vogue with Supercharged Accessories
Post #296285 1st Dec 2014 12:40pm
miggit
Make sure that all the loose paint is off the old handles, I gave mine a good scraping with a blade. Then I degreased the handle with some brake cleaner, put a thin line of PU Flex Sealer Adhesive in between the sticky strips and carefully pressed them in to place. Thumbs Up
I think that they recommended the use of silicone to glue the covers on, but I had the PU Flex kicking about and its 10 times stronger than silicone. If you've got to go and get some I'd suggest some silicon based No Nails type glue. The degrease bit is just belt and braces, to make sure that it all sticks, you could use meths, alcohol, or lighter fluid. And you don't have to go nuts with the scraping, if the paint doesn't want to come off with a blade, it should stay there when you've glued the cover on. And lastly be gentle with the handles for 24 hours!! Yesterday I couldn't spell Engineer... Today I are one!
Post #296353 1st Dec 2014 5:41pm
