Home > Technical (L322) > problems after replacing battery - L322 V8 2003 |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Your windscreen wiper relay is in a box behind the battery. Anything disturbed while they changed the battery?
22nd Nov 2014 12:21pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
take it back and tell them it all worked before but doesnt now so please fix it.. ... - .- -.
22nd Nov 2014 12:30pm |
jerrytlr Member Since: 02 Apr 2013 Location: France Posts: 66 |
Hi Stan - yes that would be the best thing to do but it is going to be hard to get back there, so would rather fix myself if it is something simple.
22nd Nov 2014 12:55pm |
ah, in that case then i would firstly do a battery disconnection as per the 'how to' in the wiki, sometimes this resets everything.. ... - .- -.
22nd Nov 2014 3:15pm |
Just a quick update - I have tried removing and replacing the battery as per the Wiki, also checked behind the battery and there is no sign of any damage or disturbance there, took the cover off and all seems fine inside (where the wiper relay is).
30th Nov 2014 8:11pm |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 |
send me your email addy and I will forward circuit diags have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
30th Nov 2014 8:51pm |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
Try a diagnostic on the bcu, looks like it has gone into transportation mode.
30th Nov 2014 9:26pm |
Thanks for the help everybody
30th Nov 2014 10:22pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
We hope you have checked the wipers' fuse, (physically) and if it's same as locking fuse? Or that one too. If you consider that it's possible to have wipers on and locking trying to actuate the moment you connect the battery, it possible a surge has happened. |
30th Nov 2014 10:38pm |
as suggested , i would double check the fuses , they might look ok but might not be so try changing them with other same rated fuses.. ... - .- -.
1st Dec 2014 9:18am |
Unnecessary quote removed
5th Dec 2014 6:59pm |
Thanks Steve that is really helpful. Fingers crossed it is the BCU, and that it can be reset.....
6th Dec 2014 10:42am |
Defiantly fixable with diagnostics if it is the BCU.
6th Dec 2014 8:41pm |
Finally had time to try the IID tool and hooray - disabling transport mode on the BCU worked so problem now solved.
20th Dec 2014 7:00pm |
