![]() | Home > In Car Electronics (L322) > Bluetooth Error - 'Phone Not Fitted' |
djharm Member Since: 28 Dec 2012 Location: breda Posts: 78 ![]() ![]() ![]() |
did you try to pair it with the right code? the code should be written somewhere on the module. cars on the side;
newapproach Member Since: 19 Nov 2014 Location: Ireland Posts: 9 ![]() |
I got no option to pair it. I just pressed the 'phone' button on the dash and I'm presented with a screen saying 'phone not fitted'. |
not familiar with the 2010 model but there should be a pairing button somewhere. cars on the side;
Go to the bluetooth settings on your phone , the code is 2121 . 2008 MY Supercharged
Excellent, thank you very much |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8686 ![]() ![]() ![]() |
Yep, you pair the phone to the car via the handset not visa versa |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
My iPhone has lead a hard life. It's refused to pair a few times. Turning BT off, then on and repairing seems to work. Previous poster is very correct. That's the code I've used, with good results. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
You can do an update on the BT software |
nobbyclark Member Since: 16 Sep 2014 Location: Cumbria Posts: 131 ![]() ![]() |
I have a 2010 model. Sometimes the BT module stops broadcasting its ID so either you can't pair or use BT if previously paired. Seems to then spark into life if you turn off, lock up and then unlock and re-start. |
55palfers Member Since: 26 Aug 2014 Location: Solihull Posts: 113 ![]() ![]() ![]() |
I have the same problem with my Blackberry - phone pairs up fine but car does not see the phone.
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 ![]() ![]() ![]() |
You always have to search for the car from the Blackberry each time you want to pair it and enter the code.
Tried that lots of times - no good.
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 ![]() ![]() ![]() |
I always had to manually connect my BB phones to the BTooth system I had on my classic (motorola system)
