Home > In Car Electronics (L322) > Bluetooth Error - 'Phone Not Fitted'
newapproach
Looking at buying a 2010 Vogue, I get a 'Phone Not Fitted' message when attempting to pair a phone. I presume BT was standard on this model so there is an error of some description. Is it difficult/costly to fix?
Post #294268 19th Nov 2014 11:44pm
djharm
Netherlands 2002 Range Rover Vogue SE Td6 Java Black
did you try to pair it with the right code? the code should be written somewhere on the module. cars on the side;
Audi A8 W12
560 SEC AMG Widebody '86
500 SE '86
Post #294270 20th Nov 2014 12:07am
newapproach
I got no option to pair it. I just pressed the 'phone' button on the dash and I'm presented with a screen saying 'phone not fitted'.
Post #294271 20th Nov 2014 12:15am
djharm
not familiar with the 2010 model but there should be a pairing button somewhere. cars on the side;
Audi A8 W12
500 SE '86
Post #294272 20th Nov 2014 12:21am
Go to the bluetooth settings on your phone , the code is 2121 . 2008 MY Supercharged
Post #294285 20th Nov 2014 12:52am
newapproach
Excellent, thank you very much Smile
Post #294287 20th Nov 2014 1:01am
Yep, you pair the phone to the car via the handset not visa versa Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #294448 20th Nov 2014 8:41pm
RR2008HSE
My iPhone has lead a hard life. It's refused to pair a few times. Turning BT off, then on and repairing seems to work. Previous poster is very correct. That's the code I've used, with good results.
Post #294939 23rd Nov 2014 11:54pm
You can do an update on the BT software Thumbs Up
Post #294943 24th Nov 2014 12:04am
nobbyclark
I have a 2010 model. Sometimes the BT module stops broadcasting its ID so either you can't pair or use BT if previously paired. Seems to then spark into life if you turn off, lock up and then unlock and re-start.
Post #294981 24th Nov 2014 1:33pm
55palfers
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Santorini Black
I have the same problem with my Blackberry - phone pairs up fine but car does not see the phone.
"Phone not fitted" message.
Dealer paired his phone without any problems.
Any ideas?
Post #295788 28th Nov 2014 9:29pm
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
You always have to search for the car from the Blackberry each time you want to pair it and enter the code.
Even though you have initially paired it, it does not search for the phone automatically.... 4.2 Supercharged Vogue SE
Post #295826 29th Nov 2014 8:19am
55palfers
Tried that lots of times - no good.
Car doesn't like Blackberries it seems.
Anyone out there with any ideas please?
Post #295883 29th Nov 2014 1:09pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
I always had to manually connect my BB phones to the BTooth system I had on my classic (motorola system)
Hoping the new car will work fine with my Sony phone
Post #296019 30th Nov 2014 7:56am
