Home > In Car Electronics (L322) > Blue tooth stoped workiing..
andrew-a
Just realised that my phone was not connected to car - 2009 5.0SC. On the Phone screen it simply says if you have a phone connect or pair it with the car. So i deleted the Land Rover connection from my phone and tried to do it again - nothing. My phone now cant find the car. So something must have happend to the bluetooth function in the car. Any ideas?
Post #295650 28th Nov 2014 12:46pm
ebajema
Better check the lefthand side rear compartment with the electronics in it. The BT module could have been damaged by water ingress, as sometimes happened on the earlier models. I hope not. Better check fuses as well.
Have you tried with another BT phone/tablet if they "see" the BT module ??
Wiggs can get you a new/updated module if needed Smile
Note that on older models (2006 I know for sure) if you take the BT module out, the MOST system fibre network is disconnected as it is daisy chained. So better leave the BT module in place until you have a replacement in case it does need to be replaced. But not sure if the 2009/2010 models still have that issue as well. MY 2010 5.0 SC Galway green and sand interior!!
Post #295659 28th Nov 2014 1:17pm
andrew-a
thanks - i will try another phone and see if it "sees" it.
Post #295660 28th Nov 2014 1:24pm
