Home > Technical (L322) > Transmission fluid leak |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Doubt it will be transmission related if its clear - IIRC transmission fluid is red, are you aware the air-con system discharges condensed water from the air via pipes either side of the g/box? - probably that I'd think |
26th Nov 2014 5:10pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
26th Nov 2014 5:41pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
seal on the electrical connector has probably failed, search, think it is a fairly common problem..... (or that could be gm box, but seem to recall ZF) Quite a cheap fix esp if you are having the box filter and oils done.
26th Nov 2014 5:56pm |
I think it's the ZF. The filter kit and all associated areas are being done. I'll add this to the list !
26th Nov 2014 5:58pm |
http://www.fullfatrr.com/forum/topic14798....rical+seal
26th Nov 2014 6:10pm |
Great read, though way beyond my skillset. It does look a standard problem, mechatronic sleeve leaking. As the filter is coming off I'll have them check and change whatever is needed.
26th Nov 2014 6:18pm |
Worth doing gen part is less than a tenner There is nothing that can't be fixed with a hammer😜😜
26th Nov 2014 6:47pm |
My mechanic geezer is ex LR/Jag so he always uses genuine Is this where I put the car details and a bit about myself ?........ |
26th Nov 2014 6:55pm |
