Home > Technical (L322) > Faults on 2003 td6
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Faults on 2003 td6
Checked my beast for faults today when I got to work.
There's 2 that are a bit of concern for me.
a) 0x56 Injection System Fault
b) 0xD7 Fuel Sender 2 Fault.
I've had the Fuel sender fault before,but not with the number 2,its only been fuel sender fault.
Does anyone know what could be causing these faults to show up.Both of these faults have shown up previously and I've cleared them.
I have read that the sender unit will need replacing at some stage,so I guess thats going to be a priority,but what about the injection system.
Would like to do both at the same time if I have to replace.
Thanks
littlecub
Post #295148 25th Nov 2014 3:05pm
miggit
Hi bud, this may or may not help, I have read on here that the there are 2 fuel senders in the tank, as it humps over the propshaft, that may explain the fuel sender 2 fault, meaning that it's the second sender not the first! As to the injector fault I haven't the foggiest idea, however I have been told that the engine appears to run quite smoothly on 5 injectors, and they have a reputation for the injector loom failing, might be this. Try unplugging the injectors one at a time with the engine running, if there is a broken wire you wont notice any difference if you pull the broken one, but it will make a big difference if you pull a good one, because you'll be down to 4 cylinders!
If you find a broken one, you might want to swap that injector over with a good one, and try again just to make sure it's the lead and not the injector Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #295313 26th Nov 2014 4:25pm
littlecub
Thanks for that Miggit
Will try your idea when I get some time.
cheers
Post #295375 27th Nov 2014 12:21am
