Home > Technical (L322) > Whistling followed by "Engine at reducued output warnin |
Av_dave Member Since: 31 Dec 2012 Location: Stourbridge West Midlands Posts: 109 |
First thing I would check is the supercharged coolant pump. This will give this message and if not already rectified yours is probably still running backwards there's quite a bit on here about it if you do a search. The difference between theory and reality is that in theory it will work. |
25th Nov 2014 6:39am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Check the obvious things like broken/ill fitting pipework... Even the smallest of air leak will upset it...
25th Nov 2014 9:11am |
Arkle Member Since: 17 Aug 2014 Location: Cheshire Posts: 173 |
Dave and Craig, many thanks for the replies.
25th Nov 2014 10:15am |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
FBH = Fuel Burning Heater.
25th Nov 2014 10:19am |
Thanks, Craig. I did see that in the manual but don't know if I have it. I'll check, but hopefully it's not there - enough fuel burning going on as it is! |
25th Nov 2014 10:22am |
I suggest to have a good look at the pipe work from air filter to supercharger. Craig is correct, any leak after the MAF (mounted just after the air filter) will upset the air/fuel mixture ratio and the lambda sensors will pick up the exhaust not being correct. The ECU will try to adjust but can't get it right with fuel trim and it can throw a fault. HOWEVER, normally that is the Engine Management Light, although I have had both on my 2006 until I updated the ECU software (and solved the gearbox solenoid issue as well) and haven't had problems after that till we left Nigeria.
25th Nov 2014 10:47am |
Meaning when the FBH is working it could be mistaken for an air leak |
25th Nov 2014 10:48am |
Thanks Paul, ebajema and Craig. I appreciate your knowledge and help. |
25th Nov 2014 2:18pm |
