![]() | Home > Wheels & Tyres > New Hankooks Fitted |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 ![]() ![]() |
i've always rated hankooks , nice job.. |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
Thanks Stan |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8353 ![]() ![]() ![]() |
You can't beat new rubber, look the part as well... |
Thanks Haylands |
Yep, sure would.... are you going to get it taken off??? Pete
Ermm dunno |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 ![]() ![]() ![]() |
Spray them black with heat resistant paint. |
Or cut the huge cast alloy ends off and replace them with tidy stainless tips that point downwards |
You should get an alignment done also unless you want them going the same way as the Pirellis Present :2008 TDV8 HSE
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
I'd would have stuck with Pirellis TBH we have no end of issues with Hancooks at work admittedly in a 17" size but each to their own
Supply is a problem - I've ordered spares to keep on the shelf just in case.
crispy2 Member Since: 18 Aug 2013 Location: Mandurah Posts: 102 ![]() ![]() ![]() |
As you say there, the 305 section does well and truly fill the guards out. How do they go for clearance on full lock? No rubbing I take it. Are the OF wheel normal offset and width?
@crispy2 - They are Hankook Ventus ST RH06 305/40R22 114V XL. I can't help you with the offset on the OF wheels I'm afraid but they are genuine 22" Tigers so the info may be out there.
