![]() | Home > Technical (L322) > l322 air suspension HEADACHE! |
Did they actually fit a new compressor? |
D8DEL Member Since: 14 Nov 2013 Location: AIRDRIE, North Lanarkshire Posts: 26 ![]() ![]() ![]() |
I fitted a new one myself before I even thought about letting anyone near her and had the same fault. Then I bought another new one, this time from Strathearn, same problem, that's when I bit the bullet and put her into them to get the problem sorted. They told me the compressor was faulty and they were going to fit another new one, compressor number 3. In the mean time, they said the valve solenoid was gubbed and needed replaced aswell as the air tank!. This work was done before I knew there was a problem with them. I didn't mind as I wanted her fixed and they're the specialists. 8 days later she was collected and driven home. No drama's on the way down but went to Equi's for ice cream after dinner to celebrate and BANG!, 'SUSPENSION FAILURE NORMAL HEIGHT ONLY' appears!. Now she doesn't even have to move and the fault appears. She's going back up on Tuesday for them to have another look, pity it cost so much and the parts were replaced when it looks like they didn't need to be. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8555 ![]() ![]() ![]() |
A specialist should know that there are more to fault codes than just the obvious, time and time again it is not the fault stated but another problem that the car "thinks" is the one shown. If they truly are a specialist then they should know how to evaluate and test items before randomly changing them.
Pete, it's a bit annoying mate but nothing that can't hopefully be sorted. They said the tank needed replaced due to corrosion and the valve solenoid was faulty. The first compressor I installed was from a 2010 RR with 38k on the clock. That didn't rectify the problem which was why I went to them and bought a brand new one, that didn't solve the problem either. That's when I took her up to them and asked them to fix her for me. A couple of days later they said the new compressor they supplied was faulty (it happens seemingly) and the new one had been ordered. 2 or 3 days later I called to see how things were going and that's when I was told the solenoid and tank had to be replaced. couldn't understand why but I went with it anyway knowing that I wouldn't need to worry about those parts failing any time soon. They noticed I had a leakoff pipe problem and fixed that for me too. They're a good bunch of guys, very helpful and pleasant to talk too. I'm confident they'll get her fixed properly this time as the options are running out for parts too replace. I'm more annoyed at myself having to get someone else to look at her as I always keep my vehicles in tip top condition myself. I could've completed a trial by elimination system myself and saved £500 labour but wouldn't have had a comeback like I have now. My patience is wearing very thin on this one and I need a positive result on Tuesday. |
Good luck mate Pete
nobbyclark Member Since: 16 Sep 2014 Location: Cumbria Posts: 131 ![]() ![]() |
Sounds like the same symptoms my D3 suffered before I got rid of it. In the end it was the entire wiring loom to all four corners that was corroded and in places there were bare bits of wire where it had stretched. At the time (3 years ago), the local LR indie in Dunkeld said he had heard of 10 that needed re-wiring. I went through a compressor and numerous sensors until the loom was replaced. That fixed it but I sold it soon after so don't know if it finally sorted the problem. It was due to a combo of crap design to allow the wiring to be exposed to the elements in places and the awful winter in 2010/11 resulting in very salty/gritty roads.
Cheers Nobby, I'll give him a shout and see if he can shed any light on it. I was up in Dunkeld today too, I could've popped in n had a blether with him. I'll keep you all informed to the goings on at Strathearn on Tuesday. |
Ok folks, quick update...
Good, can't wait to hear whats going on... Pete
Ok, called the garage for an update to see how things have been going over the last 2 days. They can't find a problem!. It's working perfectly apart from them dropping the suspension down n up 3 times and the compressor overheats. Turns out that it was my own compressor that was fitted and not the new one I bought from them, it was still in the box in the boot!. I checked this out of curiosity, each compressor has its own serial number. I'll leave it for a couple of days n call them again. I'm starting to get a bit frustrated now. |
So they said the compressor was bad, sold you a new one but never fitted it because the old one was working....
latest update...
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Sorry to hear it is not fixed - bloody annoying!
C1A20 pressure filling too slowly to tank.
