![]() | Home > Technical (L322) > l322 air suspension HEADACHE! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Just had a thought |
RS2000CUSTOM Member Since: 25 Apr 2013 Location: The Black Country Posts: 137 ![]() ![]() ![]() |
Take a read of my thread
OzTom Member Since: 11 Nov 2016 Location: Semmering Posts: 5 ![]() ![]() |
Hi,
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
wow pal , this thread is 3 years old , suggest you open a new one to get a better response |
Graeme...ta,
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2661 ![]() ![]() |
The compressor exhaust valve might not be sealing thus preventing proper pressure.
Graeme,
bobsin Member Since: 21 May 2015 Location: wolverhampton Posts: 52 ![]() ![]() |
juat a thought, have you checked your battery/alternator, 9/10 times, inactive suspension alarms related to low system voltage, after i changed my alternator, it cured a multitude of alarms on my 2004 td6, just sayin'..... |
Yep, the devil is fully charged with relatively new (6 months) battery |
hmm, although I did replace the piston ring, cleaned exhaust valve and replaced the desiccant I eventually replaced the compressor (for ca. USD 300 incl. shipping and taxes via the Chinese "Amazon") and bang - all fine, no error messages. |
stuart_2006 Member Since: 18 Jul 2018 Location: Holsworthy, Devon Posts: 129 ![]() ![]() ![]() |
Just adding another voice to the "air hose has chafed on the chassis" party. Car doesn't drop overnight, but had a hissing sound for around 30 seconds after switching off, and the occasional 'normal height only' bong message. 6mm blue hose has chafed on the chassis around 4 inches from where it comes out of the spare wheel well heading towards the valve block. Splice connector on order. |
