Home > Technical (L322) > Seat heater fault? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35253 |
steve,have you looked at RAVE...and i like the bit where you said ''trying to get to the bottom of this one '' ... - .- -.
25th Sep 2010 9:46am |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
Just having a look now. Mines 06MY but had forgotten that the seats were the same as the none facelift version.
25th Sep 2010 9:56am |
OK had a look through RAVE and tried the test mode described. Its say that if no pulses of the LED are observed then no fault is detected and I get no pulses.
25th Sep 2010 7:53pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
I wonder if they shut down if low voltage situation arises.
26th Sep 2010 7:08am |
I bet your family love you: "You can only have the heating on when you're wearing so many jumpers you can no longer move" Seriously, I've had the heated seats and steering wheel on for the last 2 months in the mornings! But then I refuse to wear a jumper or coat in the car as I see it as an extension of my livingroom, although the seats are more comfortable and the sound system is better! Anyhoo, back on topic... The system test will only throw up a code if it detects the problem at time of test and from what you've said it's intermittent. I would suggest that you have a broken/shorting element somewhere which is only causing a problem when you move about on the seat. In reality to find/repair this type of problem it's a case of taking the seat apart, although you can bet on it being in the base rather than the back. Dan |
26th Sep 2010 10:23am |
Its not that bad.. we use the Laguna for the daily school run which does't have leather. I don't go far without clothing for the conditions but thats because of the work I do. My other car is a 1990 110 CSW so even the FFRR with no heating what so ever is positively tropical by comparrison. Infact When I drive to work in the winter in the 110 if I don't catch the traffic lights right then the Sunroof starts to thaw and I get drenched.. Theres only me in the car then though as its stupid O'clock in the morning I just wrap up and open the window to let some heat in / steam from breathing out As you say back to the topic... Check the voltages first before pulling seats apart, The 1990 RRC won't allow the heater Windscreen or Rear Window heater to work if the voltage is too low so I'm pretty certain that the FFRR will have a much more clever system built in. The current draw from the heated seats and steering wheel will be very heavy in comparrison to the rest of the cars electrics so it could be the first indication of voltage problems either charge from the alternator or a battery on its way out. Do a search on checking the battery condition and also charge rate and run those tests when its working fine and also when its playing up. It will cost no more than a multimeter to check and could save lots of pulling stuff apart to search out the problem. 2010 Disco XS TDV6, 2009 Freelander 2 GS Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy". |
26th Sep 2010 3:37pm |
