Home > General > Air con.. Do you leave yours on all year round? |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
i leave mine on all year round
19th Nov 2014 2:05pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
I leave mine set on 18 degrees everything on auto and let it sort its self out. Not using on a regular basis causes more problems and you can end up with damp musty smell coming from the vents.
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
As above - I leave it one, set the temperature and let the system work it out.
19th Nov 2014 4:10pm |
nobbyclark Member Since: 16 Sep 2014 Location: Cumbria Posts: 131 |
If it's like mine, it comes on by default when you switch on. I always switch it off unless I need to cool down (which hasn't been the case in the 6 weeks since I've owned it) or else to demist the car when we all get in soaking wet (which has been the case for most of the 6 weeks since I've owned it). |
19th Nov 2014 4:34pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2265 |
I also leave mine all year for all the good reasons the others have mentioned. |
19th Nov 2014 4:51pm |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 |
Thanks people, I will leave it on all the time then, can't believe how cold this system gets, is better then any other car I've had previously |
19th Nov 2014 4:52pm |
markyp Member Since: 04 Feb 2013 Location: essex Posts: 234 |
Leave mine on, Fuel Economy 2004 vogue
19th Nov 2014 8:25pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7803 |
There are 2 types of people that don't run it all the time. Those that are going to get a big air con bill and be skint, and those that are going to get a big air con bill and not be skint.....
19th Nov 2014 9:24pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6729 |
Keep mine on all the time.
19th Nov 2014 9:56pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8530 |
There's an off button.....
19th Nov 2014 10:07pm |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
Can you turn it off then 2020 Porsche Panamera Turbo Hybrid (V FAST)
19th Nov 2014 10:08pm |
To add balance, it does dry the leather out though, which gives you an excuse to rub all that lovely conditioning cream back in..... 2011 Range Rover Vogue SE 4.4 TDV8
19th Nov 2014 10:10pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Another for leaving the air con on , I did with the land cruiser before hand but not with the D1......and lost all the gas!
19th Nov 2014 10:25pm |
Always leave the A/C on and use AUTO setting. Just adjust the temp with the temp dials. This is how the car likes it and keeps the electric dry due to it dehumidifying effects. Its AIR CONDITIONING not Air Cooling. |
19th Nov 2014 11:15pm |
