![]() | Home > General > Air con.. Do you leave yours on all year round? |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
i leave mine on all year round
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
I leave mine set on 18 degrees everything on auto and let it sort its self out. Not using on a regular basis causes more problems and you can end up with damp musty smell coming from the vents.
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
As above - I leave it one, set the temperature and let the system work it out.
nobbyclark Member Since: 16 Sep 2014 Location: Cumbria Posts: 131 ![]() ![]() |
If it's like mine, it comes on by default when you switch on. I always switch it off unless I need to cool down (which hasn't been the case in the 6 weeks since I've owned it) or else to demist the car when we all get in soaking wet (which has been the case for most of the 6 weeks since I've owned it). |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
I also leave mine all year for all the good reasons the others have mentioned. |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
Thanks people, I will leave it on all the time then, can't believe how cold this system gets, is better then any other car I've had previously |
markyp Member Since: 05 Feb 2013 Location: essex Posts: 234 ![]() ![]() ![]() |
Leave mine on, Fuel Economy |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7911 ![]() ![]() ![]() |
There are 2 types of people that don't run it all the time. Those that are going to get a big air con bill and be skint, and those that are going to get a big air con bill and not be skint.....
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6767 ![]() ![]() ![]() |
Keep mine on all the time.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
There's an off button..... |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Can you turn it off then |
To add balance, it does dry the leather out though, which gives you an excuse to rub all that lovely conditioning cream back in..... |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Another for leaving the air con on |
Always leave the A/C on and use AUTO setting. Just adjust the temp with the temp dials. This is how the car likes it and keeps the electric dry due to it dehumidifying effects. Its AIR CONDITIONING not Air Cooling. |
