Home > Technical (L322) > locking diff / axle fluid. |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 |
Good morning Gents,
18th Nov 2014 9:53am |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Woodchopper
18th Nov 2014 10:16am |
Thanks for the information Paul. I assume if I have adaptive terrain control , that I have the electronic differential that you are referring to ?
18th Nov 2014 12:25pm |
Not sure WC...
18th Nov 2014 1:47pm |
I'm waiting to go back to the dealers for the upper tailgate replaced. I'll find our then if terrain response equals electronic diff. I think it must as how else would terrain response work? MY2010 TDV8 Vogue Ipanema Sand
19th Nov 2014 7:33am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
If you go to the 4X4 screen and dial in rock crawl on the terrain response do you get two open padlock symbols ? one over the centre diff and one over the rear diff . this will tell you if the diff is open or closed and for the rear one if it the e-diff is fitted. 2008 MY Supercharged
19th Nov 2014 9:24am |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
If you look at the rear diff you will see some wires going to it if it is a locking diff. |
19th Nov 2014 9:39am |
WC...TR also adjusts the suspension height and throttle response for a given dialled in surface / terrain...
19th Nov 2014 9:43am |
Mark L Member Since: 29 Oct 2014 Location: Tamworth Posts: 121 |
Given the reoccurring problems FFRRs seem to be facing with heavily contaminated rear diff oil, I'd personally be looking to change it every 12 months with a rear locker... |
18th Dec 2014 10:53am |
