Home > Technical (L322) > locking diff / axle fluid.
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Good morning Gents,
On my oil service sheet from land rover it has the " locking differential fluid " listed under 75k or 5 years and the next item on the list is "renew front and rear axle fluid " every 10 years or 150k. ..
Is the locking diff is and axle fluid not the same thing ? Car is a 3.6 tdv8 2010.
Thank MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #293892 18th Nov 2014 9:53am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Woodchopper
From the Manual (ie I do not validate that this is correct information, but I do remember my indie having to order this lube for mine with the ETM rear diff fitted)
"If you have the optional Rear Electronic Diff, the fluid appears to be different from the standard Mechanical Open Diff system"
Rear Drive Axle/Differential -
Lubricants - Item- Specification*- Recommended lubricants:
'Open' unit = Castrol SAF-XO - 75W/90
Electronic torque managed (ETM) unit = Castrol SAF Carbon Mod Plus
(Found on page 290 of the Workshop Manual) GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #293899 18th Nov 2014 10:16am
woodchopper23
Thanks for the information Paul. I assume if I have adaptive terrain control , that I have the electronic differential that you are referring to ?
Many thanks MY2010 TDV8 Vogue Ipanema Sand
Post #293914 18th Nov 2014 12:25pm
paulmoran2
Not sure WC...
I knew i had it because the dealer told me and its on the build sheet for my car. I know it comes up as a green open padlock symbol over the the rear diff in normal driving (when you view the off road screen) which turns to an amber locked padlock when the rear diff locks in slippery situations.
Don't know if there's any other way of knowing you have it? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #293929 18th Nov 2014 1:47pm
woodchopper23
I'm waiting to go back to the dealers for the upper tailgate replaced. I'll find our then if terrain response equals electronic diff. I think it must as how else would terrain response work? MY2010 TDV8 Vogue Ipanema Sand
Post #294098 19th Nov 2014 7:33am
If you go to the 4X4 screen and dial in rock crawl on the terrain response do you get two open padlock symbols ? one over the centre diff and one over the rear diff . this will tell you if the diff is open or closed and for the rear one if it the e-diff is fitted. 2008 MY Supercharged
Post #294112 19th Nov 2014 9:24am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
If you look at the rear diff you will see some wires going to it if it is a locking diff.
Post #294121 19th Nov 2014 9:39am
paulmoran2
WC...TR also adjusts the suspension height and throttle response for a given dialled in surface / terrain...
so you can have TR without the ETM diff AFAIK with the ETM diff just being an optional extra feature. As Axle said, stick it in rock crawl or mud ruts and the padlocks should appear...if there's a padlock symbol over the rear diff, you have an ETM diff fitted.
PM2 GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #294123 19th Nov 2014 9:43am
Daniel2007VogueSE
Australia 2007 Range Rover Vogue SE TDV8 Buckingham Blue
[quote="paulmoran2"]Woodchopper
For what it's worth here in Australia we have Land Rover after Land Rover with eLocking diffs failing.
Workshops have worked out that the failures are due to 2 factors -
1. Factory over tightening the preload on the diff carrier bearings
2. The use by the LR factory of Castrol SAF Carbon Mod +
The symptoms are diff whine noise that gradually gets worse and worse till so loud that its almost as loud as the horn.
The solution is to drain the special (and very expensive) Castrol SAF CM+ oil and replace with standard diff oil (90W/140) or similar.
If this is done early enough in the vehicles life then no further diff noise presents and the eLocking diff will have a long and happy life.
I can report that we followed this advice after very loud diff whine and saved the eLocking diff before it was too late. 1989 RRC with GMC 6.5td
2005 L322 td6 HSE
2007 L322 tdv8 Vogue SE
Post #299638 18th Dec 2014 10:47am
Mark L
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
Given the reoccurring problems FFRRs seem to be facing with heavily contaminated rear diff oil, I'd personally be looking to change it every 12 months with a rear locker...
Post #299641 18th Dec 2014 10:53am
