Home > Maintenance & Mods (L322) > Did the "full air treatment" and...
J. C.
Italy 2002 Range Rover HSE Td6 Ipanema Sand
On thursday morning I received a "full air kit" (new improved filter, new breather and EGR blanking kit) for my TD6 and installed it immediately.
MPG figures, although in KM/L, can be seen in the picture below ("consumo 1"/trip 1 is before treatment, "consumo 2"/trip 2 is after). Trips are more or less the same, and consist in 80% urban jam and 20% sub-urban junctions with 55mph limit.
As for performance improvement... well... of course it makes a HUGE difference. The most noticeable thing is that now the car pulls from standstills like, well... a normal car. In traffic jam I can drive it by only applying a minimum amount of throttle. It seems to breathe properly now, if I may say so. I also noticed less slippage of the torque converter in the low revs, and also promptier gear changes in the lower band (although as smooth as usual). Only downside, a slight increase in induction noise.
So far, so good. Thumbs Up
There is a question I have: in urban traffic jam, when decelerating by lifting the throttle between 1500 and 2000rpm, I can clearly hear a sort of "whoomp" from the engine bay. Cannot describe it in other ways, but it reminds me of the noise of an overheated clutch in a manual car, except for the fact that it happens when decelerating. No discernable mechanical vibration/noises associated. This symptom happens only in city traffic and in the aformentioned rpm band, with warm engine.
What can it be? Is it related to the torque converter (it has 40.000kms from new, as the gearbox,, oil flushed on May 2014), is it the turbo releasing pressure? Opinions welcome!
Post #293511 16th Nov 2014 4:45pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
I had the same on my old TD6. dont worry its just the noise the turbo makes. nothing wrong. Thumbs Up
Post #293541 16th Nov 2014 6:19pm
J. C.
Are you sure? That is excellent news! Thumbs Up Thumbs Up Thumbs Up Roberto
_________________________________________________________________
2002 L322 TD6 HSE in Ipanema Sand with "suicide charcoal" interior.
Other current cars: 1990 MB R129 300SL-24, BMW 118d E87.
Previous cars: '87 Mitsubishi Pajero, '96 Lancia Dedra SW, '91 Lancia Delta Integrale EVO, '01 MB CLK 200k EVO, '03 MB R230 SL 500, '99 Range Rover P38 4,6 HSE.
Post #293551 16th Nov 2014 6:35pm
mjdronfield
Mine def has more induction noise after fitting k & n.
Egr removal will make turbo spool up slightly sooner I believe.
If you have a remap and come off the throttle, it almost sounds like a Subaru Imprezza....
Tsssst...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #293557 16th Nov 2014 7:02pm
J. C.
Mine sounds more like a "weee-ooomph", more noisy, less whispering... Roberto
Post #293558 16th Nov 2014 7:07pm
What is the "breather" you changed ? .
Post #293588 16th Nov 2014 8:16pm
J. C.
Joe, it's the crankcase breather filter. Roberto
Post #293607 16th Nov 2014 8:39pm
Yes it is, having a blonde moment Laughing
Replaced mine when the dipstick kept shooting out of its holster everytime I started the car Smile .
Post #293615 16th Nov 2014 8:44pm
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
that looks quite good
how much did it cost to get that work done? what do you reckon the improvement in mpg is % wise?
Post #293716 17th Nov 2014 12:18pm
J. C.
Hi Andy, cost for the stuff (egr blanking kit, breather filter and new air filter, shipped) was 143€. Fitted by myself.
As for MPG, maybe it's a bit too early, but I can safely say that there's a good 10-20% improvement, if not even more in some circumstances. Roberto
Post #293719 17th Nov 2014 12:30pm
Weegie
7.9 km/l to 9.9 km/l equates to going from 22.32 mpg to 27.97 mpg according to my conversion tables. Thumbs Up John
GAP iiD BT
Post #293720 17th Nov 2014 12:31pm
mjdronfield
The mpg will settle after a while.
Did you fit the upgraded vortex crankcase breather from BMW ?
Never needs changing again........
http://www.fullfatrr.com/forum/topic12853....e+breather
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #293766 17th Nov 2014 5:21pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Occasionally at the twin traffic lights I get the urge to floor it after holding the brake on for it to get to 2000 revs to launch it, laugh at the other car who thinks its a block on wheels in the rear view mirror Rolling with laughter _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #293877 18th Nov 2014 8:49am
andyleeds
what do we think the mpg would settle at ? and how easier job is it as that would appear to be a good thing to do?
Post #293954 18th Nov 2014 4:19pm
mjdronfield
My mpg is roughly where it was before, but car is more lively.
Have a search for crankcase breather and I'm sure there is a how to.
No more difficult than changing the original foam element, though to be fair, the garage did mine whilst servicing it.
If you fit a performance air filter as well, you can save a bit on servicing as they don't need to be changed and the cover of the engine doesn't need to come off......
Though you don't leave the performance air filter forever....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #293969 18th Nov 2014 5:33pm
