Home > Technical (L322) > Battery flat/drained |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
I think you should trust your instincts.
25th Sep 2010 6:13pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35122 |
like DELAMO says now that temperatures are starting to go down ,this is the time when problems will show..the FFRR takes a lot of power when it does its ECU checks when the ignition is on as i have found out when mine went flat...may i suggest 'europarts' for a bosch [varta badged] 110ah,920 crank battery at £119... ... - .- -.
25th Sep 2010 6:34pm |
Duke Thrust Member Since: 07 Jun 2010 Location: Gloucestershire Posts: 59 |
It could well be temperature related, it dropped to 4 degrees this morning.
25th Sep 2010 6:48pm |
the battery type number is 020... ... - .- -.
25th Sep 2010 6:50pm |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 |
when i had my battery done the old one was still green but was completly shagged the guy who put the new one in said that it will show green as long as the plates are not dammaged but after so long they fur up and suddenly stop holding the charge. 02 Range Rover HSE Zambezie silver 4.4 |
26th Sep 2010 10:41pm |
