Home > Technical (L322) > Instruments |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
Advice please team, I am not sure if this should be in technical electronic or maintenance treads so start here.
15th Nov 2014 3:09pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Hi Andy. You really have had a run of bad luck lately.
15th Nov 2014 5:42pm |
Hi
16th Nov 2014 9:25am |
Bump.
18th Jan 2015 11:25am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8244 |
These folk are one of the leading repairers...
18th Jan 2015 11:41am |
Thought about the battery I have given it a good charge, it didn't seem to make any difference but the fault is intermittent, only other issue is air suspension warning coming on and off. If I look at off road screen while the message is on all four wheels show the little red icons are at the bottom of the wheels then after a few minutes it goes back to normal with icons in their normal position? Mine was a blue one! |
18th Jan 2015 12:41pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7939 |
Mine seemed to charge ok, but a proper battery tester showed it as defective.
18th Jan 2015 12:46pm |
