![]() | Home > Maintenance & Mods (L322) > 2010 Front Bumper Lower Winglet / Spoiler removal |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Hello Gents
Cheers...spotted the screws once I had a torch...also removed the front lower black plastic splitter too (just incase I needed to access the towing eye)
Paul, the little white fixings just wriggle off too and normally get lost when the screws are not holding them in place pal |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3146 ![]() ![]() ![]() |
Did you manage to get these removed and refitted Paul?
Yes DH...easy enough . There's 2 screws up under each winglet that you undo and then slide the winglet rearwards to remove
Thanks Paul.
You might to take the fogs out so you can get your hand in above to locate the 3 tongues ( that are a little bendy) into the 3 holes of the winglet / diffuser GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Brilliant. Thanks for the heads up!
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
I have experienced your gentle offroading
Nowt planned Howard as the FF is in the body shop getting the scuffs buffed . That's an old post of mine in prep for our escapade last week.
Ps...sorry if I upset your poor little tummy with my rough driving |
David, the torx screw's that holds all the lower dash parts together, glovebox, plastic panels and the wood/piano panel next to your knee... If you remove one then match it to what you have, you will be on the right track sir ![]() |
Thanks Craig.
