Home > Maintenance & Mods (L322) > 2010 Front Bumper Lower Winglet / Spoiler removal |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Hello Gents
12th Oct 2014 7:46am |
Cheers...spotted the screws once I had a torch...also removed the front lower black plastic splitter too (just incase I needed to access the towing eye)
12th Oct 2014 2:33pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Paul, the little white fixings just wriggle off too and normally get lost when the screws are not holding them in place pal |
12th Oct 2014 2:57pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
Did you manage to get these removed and refitted Paul?
15th Nov 2014 7:00pm |
Yes DH...easy enough . There's 2 screws up under each winglet that you undo and then slide the winglet rearwards to remove
15th Nov 2014 7:07pm |
Thanks Paul.
15th Nov 2014 7:17pm |
You might to take the fogs out so you can get your hand in above to locate the 3 tongues ( that are a little bendy) into the 3 holes of the winglet / diffuser GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
15th Nov 2014 7:20pm |
Brilliant. Thanks for the heads up!
15th Nov 2014 7:25pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
I have experienced your gentle offroading
15th Nov 2014 8:19pm |
Nowt planned Howard as the FF is in the body shop getting the scuffs buffed . That's an old post of mine in prep for our escapade last week.
15th Nov 2014 8:32pm |
Ps...sorry if I upset your poor little tummy with my rough driving GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
David, the torx screw's that holds all the lower dash parts together, glovebox, plastic panels and the wood/piano panel next to your knee... If you remove one then match it to what you have, you will be on the right track sir |
15th Nov 2014 9:30pm |
Thanks Craig.
16th Nov 2014 4:53pm |
