![]() | Home > Maintenance & Mods (L322) > TD6 Coolant change |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
Evening
Got it sorted
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
you didnt have to trawl the net for that WM, a link is in our wiki... ... - .- -.
Hi Stan
i stand corrected |
Thats very formal of you.
Bloke Member Since: 13 May 2019 Location: On the road to Oban Posts: 120 ![]() ![]() ![]() |
Excellent post and just what I was looking for. Thanks OP. |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
After you drain the radiator run the engine for a minute it will expel some coolant |
Replaced coolant last night. Undid by hand the system drain located at the bottom RHS of the radiator, removed expansion tank screw cap and bleeder screw from EGR heater and allowed to fully drain. Did run engine for a minute to try and get all the old coolant out. Checked old coolant and my tester was showing it was around 15% strength. I then ran the garden hose through the expansion tank and ran that for a few minutes. It ran clear so not much if any corrosion present which is good. |
RAVE with TD6 here .
