![]() | Home > Wheels & Tyres > Pirellis or Michelin |
corinthian99 Member Since: 02 May 2014 Location: Hitchin Posts: 38 ![]() ![]() ![]() |
Evil time has come to replace the rear no brand crap rubber - night drive across Cornwall in the rain was a bit squirrely last night. Local tyre place in Falmouth has given a price of £165 for Pirellis Scorpions or £169 + £50 rebate card for Michelin Lattitudes. Prices are each, fitted inc. VAT.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 ![]() ![]() ![]() |
Goodyear wranglers on mine. Never had an issue, neither for 4 years with them on my Disco 2.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 ![]() ![]() |
I've got pirellis' on the front and general grabber at's on the rear, which are fab! I'd stick with the pirelli if its only ever going to see tarmac, I've always found the michelin a bit nervous in the wet, but they do last! Yesterday I couldn't spell Engineer... Today I are one!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8673 ![]() ![]() ![]() |
Got lattitudes on the ffrr, and they do last well, and hve been fine in terms of wet and dry handling, have wranglers on the disco, also good! And scorps on the disco 18" which are also fine tyres. Personally think the scorps edge it, but the wranglers are rated well over on disco4.
Iota, but they've got a good bit of tread left so they can stay for now. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7968 ![]() ![]() ![]() |
IMHO you should never mix rubber - same tyres all round. |
Not exactly correct there bud, don't mix crossply and radial tires, and having the same make on the axle helps, and obviously the same size. Which in the case of a FFRR, being a full time 4x4, all the tires must be the same size all round. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
sometimes its not practical or affordable to have all the same , certainly roughly the same depths and same makes on each axle is advised.. ... - .- -.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
I think Alistair is trying to point out that as you need to run all the same sized tyres on a FF, running Grabbers only on one axle could mean (as the treat is deeper) a larger rolling circumference on one axle than the other...
Unnecessary quote removed
Pirellis or Michelin?
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
As Gaz said |
I wasn't referring to the law - just my opinion - for me it has to be the same rubber & tread pattern all round - I wouldn't mix brands I know many people do, but i learnt from expensive experience that they have different handling characteristics and behave differently - and I know the FFRR isn't a sports car, but I just can't help myself ![]() I also wouldn't run below 3mm even though the law says 1.6 You pays your money...... |
Im also getting a little more picky about tyres as i get older/can afford not to put spandex radials on my cars.
