Home > Maintenance & Mods (L322) > Tow Bar Height Grrrr !!
Page 1 of 3 123>
noworries4x4
What were Land Rover thinking ??? What is the most popular trailer in the country yes you guessed it an Ifor Williams therefore why sell a tow bar to low to attach to one.
As some of you might know I have only just replaced my trusty old P38 with a fullfat and I am starting to sort some bits and pieces out, fullfat sticker on, crappy removable towbar off and fit a proper one.
So its back off the car and as I don't have a decent pillar drill at home or 16.5mm drill bits its off to the firm that does all our fabrication work this week for some more holes, might get them to cut the bottom off as well as it is a bit low / plough.
Any way in the for sale section anybody want a removable towbar and receiver c/w cubby hole converter to keep it in. If everything is under control you are not going fast enough.
MY 16 Discovery 4 Commercial Workshop and Escort Vehicle
MY 12 Full Fat TDV8
1952 Series 1 80" 3ltr 6cyl
Post #291759 9th Nov 2014 9:20am
mzplcg
The UE standard for towball height is between 14 and 16.5 inches from the floor to the centre line of the ball. If yours is inside those measurements then the trailer isthe non-conforming item. I have the farmer's hitch like you and on the top set of holes with a regular towball mine sits at just under 16 inches. Thumbs Up
Post #291769 9th Nov 2014 9:44am
is your FF in standard suspension mode NW ? ... - .- -.
Post #291776 9th Nov 2014 9:51am
noworries4x4
I honestly have not put a tape measure on it, but I know the Tri axle Ifor is bang level behind the 90 and I have to drop the hitch 2 holes for the Indespension Tow a Van, the difference in the height in that picture is 60mm that's a lot the trailer would be running on its front axle. If everything is under control you are not going fast enough.
MY 12 Full Fat TDV8
Post #291777 9th Nov 2014 9:53am
noworries4x4
Yes the balls were level when it was in "off road" and the bottom of the hitch plate was only 3" off the floor when in "access" If everything is under control you are not going fast enough.
MY 12 Full Fat TDV8
Post #291778 9th Nov 2014 9:55am
I hate my farmers hitch tower, the number of tarmac trenches I have managed to dig are unbelievable. Anyone wanting to swap for a QR hitch? Whistle
Post #291780 9th Nov 2014 9:58am
mzplcg
Yes, but until you know the running height of the Ifor how do you know it conforms with EU standards. Defenders have many options for heights including sliding adjustables so that's no indication of conformity, only flexibility beyond what is standard.
USA boat trailers are well known for this as well, they run far too high for EU standards as anyone who owns a Mastercraft will tell you. I drilled an extra set of holes for this damn thing which I did on the car as I don't have a pillar drill.
Post #291784 9th Nov 2014 10:07am
Mine seems to work fine on the top setting for both Ifor Williams and MasterCraft Cool
Post #291786 9th Nov 2014 10:21am
noworries4x4
Strangely there is one For Sale in the For Sale section, some one is interested already so you can have second dibbs if you want. If everything is under control you are not going fast enough.
MY 12 Full Fat TDV8
Post #291787 9th Nov 2014 10:26am
mzplcg
You have an EU trailer there. Mine is on a US trailer with hydraulic brakes and the ride height is a lot higher. Gimme a sec and I'll dig out a pic.
Here, you can just make out the master cylinder on the hitch. That runs at almost 18 inches off the floor to the centre of the ball.
Post #291788 9th Nov 2014 10:27am
Mines a U.S. trailer - 2" ball, hydraulic brakes and no handbrake Thumbs Up
Yours actually looks like it was modified to sit higher - mine just runs straight from the horizontal trailer box section.
Post #291790 9th Nov 2014 10:30am
I really don't want to buy one if I can do a straight swap Rolling Eyes
Edit for typo Shocked
Post #291800 9th Nov 2014 11:15am
mzplcg
No, not modified but not box section either. It's all made of C section steel. As I imported it from the States about 15 years ago. All I've ever done is service the brakes.
And the FF set in standard ride height and caravan height set of holes on the hitch...........
Post #291801 9th Nov 2014 11:19am
Here's mine - seems to sit at the right height on the top setting of the farmers hitch
Post #291806 9th Nov 2014 11:40am
RiccartonRR
Re: Tow Bar Height Grrrr !!
Completely agree. Drilling two more holes further up sorts it though (there's a huge difference between towing a double axle trailer with a slightly too low hitch to a tri-axle). Mine was horrific on the motorway and very unstable even when loaded.
While you're at it get them to build up the farmer hitch with some weld and then machine it back so it is a snug fit in the holster. Once you've used the tow bar you'll notice you can move it up / down / sideway a few mm and it hammers something awful in the car. I built mine up and it's now very snug with zero movement after several thousand miles towing the tri-axle.
Two holes drilled further up and the bottom but off to neaten things up and now the tri-axle is a stable as it should be (even with 6 round bales of haylage aboard) Thumbs Up
Good luck!
Post #291808 9th Nov 2014 11:58am
Page 1 of 3 123>
