Home > Maintenance & Mods (L322) > Tow Bar Height Grrrr !! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Hydraulic brakes are available on UK trailers, they are not an American invention! Unlike the electric bakes, nice idea but totally banned over here, something to do with if your lights short out you've got no lights and no brakes
11th Nov 2014 1:43pm |
noworries4x4 Member Since: 03 Oct 2013 Location: Newton Abbot Posts: 166 |
I did consider using a Dixon bate slider but they rattle and bang something terrible the one on my dads disco was very noisy, also I kept cracking my shins on it hateful painful bruises.
11th Nov 2014 10:38pm |
Dam those designers at Land Rover, if only the tight wads had made the hitch an inch longer! I wasn't too sure if that would work but was worth a try! That height adjuster hitch is not a Dixon Bate, it is nearer to a Writter, as such it uses 2 pins instead of the 1, like I have , and does indeed rattle! Anyway I'm glade mine makes a little noise, that way I only poop myself if it all goes quiet, and I start checking the rear view mirror
11th Nov 2014 11:02pm |
Something about that tow ball shin connection that proper smarts. If everything is under control you are not going fast enough.
11th Nov 2014 11:13pm |
It is at the optimum height to cause the maximum pain Yesterday I couldn't spell Engineer... Today I are one!
11th Nov 2014 11:20pm |
