![]() | Home > Technical (L322) > Park Heater Replacement Remote |
welsh19 Member Since: 19 Jan 2012 Location: Swansea Posts: 17 ![]() ![]() ![]() |
Hi,
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 ![]() ![]() ![]() |
Hi welsh19
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 ![]() ![]() ![]() |
Welsh19 i would check to make sure that you have the telestart module first as not all 2005 models had it as standard. I have a Vogue but no telestart which i found out after buying a T91 remote!!! So have one here if anyone wants one.
thanks for the reply, i will check tomorrow for what you said to look for, 2005 RR HSE 2.9 TD6 Auto |
kam100 Member Since: 25 Mar 2007 Location: Midlands Posts: 47 ![]() ![]() ![]() |
I have a 2005/55 Range Rover Vogue SE, have just bought a replacement heater fob, so going to give this a try and see if it works. Anyone else had any experience with this since?
This method of taking the fuse out and putting back in after 10 seconds, then holding the OFF button on the remote works.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
http://www.webasto.com/fileadmin/webasto_f...rt-t91.pdf
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Just make sure the telestart module is not a T60, as the T91 will not pair. I got this info from Webasto themselves. |
