Home > Technical (L322) > Park Heater Replacement Remote |
welsh19 Member Since: 19 Jan 2012 Location: Swansea Posts: 17 |
Hi,
19th Jan 2012 10:39pm |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 |
Hi welsh19
19th Jan 2012 10:48pm |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 |
Welsh19 i would check to make sure that you have the telestart module first as not all 2005 models had it as standard. I have a Vogue but no telestart which i found out after buying a T91 remote!!! So have one here if anyone wants one.
19th Jan 2012 10:56pm |
thanks for the reply, i will check tomorrow for what you said to look for, 2005 RR HSE 2.9 TD6 Auto |
19th Jan 2012 11:00pm |
kam100 Member Since: 25 Mar 2007 Location: Midlands Posts: 47 |
I have a 2005/55 Range Rover Vogue SE, have just bought a replacement heater fob, so going to give this a try and see if it works. Anyone else had any experience with this since?
3rd Nov 2014 2:44pm |
This method of taking the fuse out and putting back in after 10 seconds, then holding the OFF button on the remote works.
7th Nov 2014 7:02pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
http://www.webasto.com/fileadmin/webasto_f...rt-t91.pdf
8th Nov 2014 8:27am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Just make sure the telestart module is not a T60, as the T91 will not pair. I got this info from Webasto themselves. |
16th Nov 2014 6:32pm |
