![]() | Home > Group Buys > Possible discount on the android head unit |
Trossachsturbo Member Since: 29 Jan 2014 Location: Central Posts: 24 ![]() ![]() ![]() |
Would be interested subject to price |
Me also - maybe. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6760 ![]() ![]() ![]() |
What unit? Got - 2017 SDV8 Autobiography in Loire Blue
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Also interested, but would want Erisin to provide a little more in the way of installation instructions, especially the audio side of things (connecting up to existing etc.) Not an electrical or audio expert |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
thinking of upgrading to android from the S60
Completely agree re the assistance in installation |
believe it may be this one or very similar http://www.fullfatrr.com/forum/topic25796.html |
hex Member Since: 22 Jun 2014 Location: coventry Posts: 108 ![]() ![]() ![]() |
This is the current thread with lots of info on
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8518 ![]() ![]() ![]() |
As it stands at the moment these are not plug and play, you will have to bypass the DSP amp and run the unit direct to the speakers (it does have it's own internal amp)
it can be plug and play(ish) with a bit of cheeting
New I'd seen that somewhere.... so as I understand you plugged the long lead from the new unit through a handsfree phone piggy back plug setup so you had the radio plug plugged in?? Pete
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7897 ![]() ![]() ![]() |
It's what I was getting at in the other thread. Piggy back the existing system. From looking at the plug for phone in the BM54 loom, I still recon you'd only get mono sound. The phone only uses a single channel feed.
the mono bit of the parrot adapter is not used so you get the full DSP sound
If all you need is a phone adapter loom to interface to the existing systems then it makes things much simpler, as you say.
