Home > Group Buys > Possible discount on the android head unit |
Trossachsturbo Member Since: 29 Jan 2014 Location: Central Posts: 24 |
Would be interested subject to price |
7th Nov 2014 9:32am |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Me also - maybe. |
7th Nov 2014 9:33am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6737 |
What unit? Got - 2017 SDV8 Autobiography in Loire Blue
7th Nov 2014 9:53am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
Also interested, but would want Erisin to provide a little more in the way of installation instructions, especially the audio side of things (connecting up to existing etc.) Not an electrical or audio expert .
7th Nov 2014 11:43am |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
thinking of upgrading to android from the S60
7th Nov 2014 11:51am |
Completely agree re the assistance in installation |
believe it may be this one or very similar http://www.fullfatrr.com/forum/topic25796.html |
7th Nov 2014 11:58am |
hex Member Since: 22 Jun 2014 Location: coventry Posts: 108 |
This is the current thread with lots of info on
7th Nov 2014 1:09pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8334 |
As it stands at the moment these are not plug and play, you will have to bypass the DSP amp and run the unit direct to the speakers (it does have it's own internal amp)
7th Nov 2014 2:31pm |
it can be plug and play(ish) with a bit of cheeting
7th Nov 2014 7:43pm |
New I'd seen that somewhere.... so as I understand you plugged the long lead from the new unit through a handsfree phone piggy back plug setup so you had the radio plug plugged in?? Pete
7th Nov 2014 8:38pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7832 |
It's what I was getting at in the other thread. Piggy back the existing system. From looking at the plug for phone in the BM54 loom, I still recon you'd only get mono sound. The phone only uses a single channel feed.
7th Nov 2014 9:33pm |
the mono bit of the parrot adapter is not used so you get the full DSP sound
8th Nov 2014 10:38am |
If all you need is a phone adapter loom to interface to the existing systems then it makes things much simpler, as you say.
8th Nov 2014 11:06am |
