![]() | Home > Maintenance & Mods (L322) > Headlamps appear to be blinding other car drivers, ugh ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
having a 'facelift' makes me think its part of the problem ...did you do it yourself and have you re-checked all the connections.. ... - .- -.
Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299 ![]() ![]() |
No I didnt do it myself Stan, a friend of mine did it for me, who has been a very good mechanic for over 30 years. All wiring was done to a professional standard and has been working for over 6 months with no problems at all.
Run it into an MOT station and ask them to check for you if they are set up correctly? Probably won't charge you either |
Ok will try that but if they turn out to be pointing to high is there an adjustable 'thing' to correct it ? |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
There are two 6mm allen key adjustment points on the top back of the headlamp assembly as you look down on the assembly from above. The one on the inner side (i.e. furthest from the wing) does the vertical adjustment and the one on the outer side (i.e. closest to the wing) does the horizontal adjustment.
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 ![]() ![]() ![]() |
Funny that this post should appear, I'm having the exact same problem. Facelift was done in the summer and I've hardly driven the car at night time. I've been flashed a few times this week and yes have noticed people adjusting their rear view mirrors. I will try to set the beam up a bit better tonight |
The public are now free (or free'er) from my blinding light attack against them.
Who did your conversion? Why were your lights not set to MOT standard within the job ![]() |
The conversion was done by myself, as a hobby I restore landrovers and dabble with motorsport preparation. I decided to spend a bit of time on my FF which I was planning to get rid off. I did inspect the beam pattern but not to MOT standards, then the car went in for a full respray, I had it back for a few weeks but didn't really drive it much. Then I went out of the country for a month for work & holiday. I'll put this one down to experience and it will be having the beams setup by an mot approved facility |
Ahh |
Glad to hear you're not blinding everybody on the roads, spent 15 mins last night adjusting my headlights as well, cos I don't like being blinded and no one else does!! ![]() ![]() |
