Home > Maintenance & Mods (L322) > First signs of cold weather and.., |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
Diesel waxing? Cloud point of diesel is about 3degrees C. Is your pre-heater kicking in OK? John
4th Nov 2014 12:55pm |
Flunter Member Since: 27 Apr 2014 Location: East Yorkshire Posts: 26 |
To be honest I don't know. I did notice the message 'Pre Heating' on the dash before I started the car.
4th Nov 2014 1:02pm |
At 3 degrees there is no chance it was diesel waxing. Could have been a glitch with the electrics if the battery is on its way out and when you crank the engine it pulls all the voltage out to get the engine going leaving nothing in reserve once it starts.
4th Nov 2014 5:19pm |
Thanks for the replies.
4th Nov 2014 5:44pm |
Update:
28th Nov 2014 2:20pm |
Any tips? Not Representative! |
30th Nov 2014 11:32am |
I guess from the lack of response that I'm talking through my backside but you're just too polite to say! Not Representative! |
4th Dec 2014 10:12am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
People on this site are extremely knowledgeable and helpful but if no one has any input you probably wont get a reply . So maybe keep the toys in the cot and investigate a little , like is it throwing any fault codes ? 2008 MY Supercharged
4th Dec 2014 10:21am |
More likely nobody knows anything - we have not heard of a prob such as this a (and we hear lots.. ).
4th Dec 2014 10:26am |
I am aware of the knowledge of the members on this forum which is why I don't post my issues anywhere else. As it is not my style, my toys always stay well and truly cot side! No faults are being shown, I would have stated them in my first post. I've done the usual Goggle searches but failed to find any similar problem. If it helps at all, providing the engine doesn't drop below 2000rpm (which generally means Sport mode) and I resist putting my foot down I can maintain around 45 - 50mph, the problem returns if I need to slow or stop for junctions etc, however a quick blip on the accelerator and away I go again. Thank you both for taking the time. Not Representative! |
4th Dec 2014 10:37am |
Well, I've never had a TD6 but from what you describe I think you can rule out anything electronic due to the lack of fault codes. Similar symptoms have been described for failing fuel lift pumps, split turbocharger hoses etc.
4th Dec 2014 11:37am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
I'd go with 47p2 above, fuel filter.
4th Dec 2014 12:08pm |
I have been thinking about this problem for a bit now and can't really say that I have a plausible explanation. It sounds like there is a fuel restriction of some sorts that disappears when the engine heats up a bit. Looking at the relatively short time, I would be looking at either fuel filter and pump or maybe some small crack in the inlet tract letting air in and then closing due to the warming up.
4th Dec 2014 12:56pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
I don't know! But if you'll accept some guesses, here I go:
5th Dec 2014 1:45am |
