Home > Maintenance & Mods (L322) > 2006-2009 conversion
quabba
Scotland 2005 Range Rover Autobiography 4.4 V8 Java Black
Hi I've bought a 2005 vogue that has had a front end conversion.
The headlights and fog lights work ok but the washer jets and headlight leveling doesn't.
Anyone done a conversion that could help me, ie parts I will need or wiring examples.
Going to need it done before mot
Post #290548 3rd Nov 2014 10:47pm
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
Hi,
The headlamps won't auto level as the conversion offers no facility to have this feature working. The lamps should be setup as best as possible and left that way. The same goes for bi directional headlamps on later models.
As for the washer jets, it's likely the conversion was only half done, you need a higher powered washer pump, this only fits in the later style screenwash reservoir. It's an easy enough job to fit, bumper off, arch liner off, remove old, replace new. Then the arch liner needs a little trim at the front. Parts total to about £150 And consist of reservoir, 2 x pump for front / rear jets, 1 x pump for front jets, 3 x rubber seals. You can use your original level sensor.
Steve
Post #290565 4th Nov 2014 7:53am
quabba
Thanks for that, Will it not fail it's mot due to the lights not self levelling. My M3 failed due to this.
Post #290569 4th Nov 2014 8:10am
SteveyD
Not that I'm aware of, your issue will be the wash jets not working. That's a definite fail.
Post #290570 4th Nov 2014 8:24am
quabba
Did the old lights with the wipers on them self level? Not sure why the new lights wouldn't have this option.
Just noticed also that the front parking sensors don't work as well Shocked
I've gone and bought another cracker here Smile
Post #290572 4th Nov 2014 8:36am
Self levelling suspension so no need for dancing lights . 2008 MY Supercharged
Post #290574 4th Nov 2014 8:58am
quabba
Hopefully get the bumper off at the weekend
Post #291279 6th Nov 2014 8:19pm
