![]() | Home > Maintenance & Mods (L322) > Flexi plate |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Usually the brake disc mud shields rattle got them on mine to do. Well covered on this superb forum. Don't know about flexi plate rattle unless it's something I haven't heard about. Hope this helps.
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
Flex plate rattle could be the flex plate which is between the flywheel and torque convertor.
B |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8405 ![]() ![]() ![]() |
Yep, flex plate is between TC and box, gearbox out job....
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1792 ![]() ![]() |
If it is only on start up, the starter motors are prone to rattle too |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
As above the flex plate bolts the torque converter to the crank (equivalent of a flywheel).
HGv driver Member Since: 16 Sep 2014 Location: Cardiff Posts: 169 ![]() ![]() |
thank you for the info its booked in for monday morning so need to wait and see |
Yes been confirmed I got a cracked flex plate new one being fitted tomorrow £650 all in ouch ,I was wondering ( I didn't think to ask at the time) will the gearbox need to be emptied of oil and refilled to do this? |
I don't think it would be necessary, but probably good practice, for the cost of a new torque convertor I'd get that changed depending on the mileage.... Pete
