Home > Maintenance & Mods (L322) > Flexi plate
HGv driver
Wales
Flexi plate
Just been told what I thought to be an engine rattle is a flexi plate rattle now I'm not into getting my hands dirty anyone know how big and expensive job this is to replace? Thanks folks
Post #290026 31st Oct 2014 7:02pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Usually the brake disc mud shields rattle got them on mine to do. Well covered on this superb forum. Don't know about flexi plate rattle unless it's something I haven't heard about. Hope this helps.
Greg.
Post #290029 31st Oct 2014 7:16pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Flex plate rattle could be the flex plate which is between the flywheel and torque convertor.
If that is the case, to replace it is a gearbox out.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #290032 31st Oct 2014 7:23pm
gregdav
B Censored y hell Shocked that sounds expensive.
Post #290035 31st Oct 2014 7:28pm
Yep, flex plate is between TC and box, gearbox out job....
Get under there and give the catalytic converters a whack, the insides work loose and this can sound just the same... Pete
Post #290041 31st Oct 2014 8:07pm
Mikey
If it is only on start up, the starter motors are prone to rattle too Thumbs Up
Post #290044 31st Oct 2014 8:12pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
As above the flex plate bolts the torque converter to the crank (equivalent of a flywheel).
Rattle in that area can be down to loose bolts or cracked plate.
The flex plate to torque convertor bolts can be checked for tightness without removing anything.
The flex plate to crank bolts can only be checked with the gearbox removed.
I had a similar rattle and ended up taking the gearbox off (and got the torque converter rebuilt at the same time, worth doing if around 100k miles and never been done) only to end up with the same issue as I couldn't find a problem. It only cost me £150 to get the torque converter rebuilt plus cost of replacing the gearbox oil so about £250-£300. A garage will likely charge around £800 for the same.
I'm now thinking the rattle is from the front end i.e. timing chain. In the next couple of weeks I'm replacing the timing chain and guides plus rebuilding the VANOS. Total cost about £1500 including tools, Garage would be about £3k for the same job.
That's for M62 V8, TD6 shouldn't need the above, I don't think they have issues with the timing chain and guides.
Flex plate on the TD6 only has 3 securing bolts to the TC compared to 4 on the M62 so more likely that's the issue.
Could just be a case of tightening a bolt.
Post #290046 31st Oct 2014 8:13pm
HGv driver
Wales
thank you for the info its booked in for monday morning so need to wait and see
Post #290143 1st Nov 2014 12:59pm
HGv driver
Wales
Yes been confirmed I got a cracked flex plate new one being fitted tomorrow £650 all in ouch ,I was wondering ( I didn't think to ask at the time) will the gearbox need to be emptied of oil and refilled to do this?
Post #290545 3rd Nov 2014 10:35pm
I don't think it would be necessary, but probably good practice, for the cost of a new torque convertor I'd get that changed depending on the mileage.... Pete
Post #290554 3rd Nov 2014 11:21pm
