Home > Maintenance & Mods (L322) > Before you get under a car supported by a hydraulic jack...
Page 2 of 3 <123>
This method saves having to chop down the tree and cutting it up into ramps.
Post #289879 30th Oct 2014 10:38pm
What a nutter... (your neighbour, not you!!!)
If using axle stands just make sure they are up to the job.... cheap jobbies from Halfords are not strong enough for a Full Fat... Pete
Post #289880 30th Oct 2014 10:38pm
Just can't work this one out. How did he get there?
Post #289881 30th Oct 2014 10:42pm
I am also a nutter. Smile
Post #289882 30th Oct 2014 10:43pm
This jack has all the mobiliy benefits of a trolly jack, with the non-colapse-ability of an axle stand.
Post #289883 30th Oct 2014 10:47pm
Here's a good alternative to a jack. A pressurised vessel filled with a flamable gas.
Post #289884 30th Oct 2014 10:52pm
mjdronfield
Rolling with laughter
Brilliant.....
Or you could just have the right tool for the job Whistle
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #289923 31st Oct 2014 8:55am
Or use this method ...
Post #289931 31st Oct 2014 10:10am
miggit
Is that one of those Air Bag Jacks? and were can I get one of them from? Yesterday I couldn't spell Engineer... Today I are one!
Post #290100 1st Nov 2014 12:58am
miggit
I found this picture of a small Russian Jack Shocked
What in Gods name do they feed them on? Yesterday I couldn't spell Engineer... Today I are one!
Post #290101 1st Nov 2014 1:22am
Post #305910 17th Jan 2015 6:28pm
miggit
Kurt, is that the same Lada from the other side? Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #305993 17th Jan 2015 11:43pm
mzplcg
I've seen my fair share too. No pictures as it was a long time ago when we didn't have digital cameras. Scissor jacks underneath diffs, lengths of 4x2 on end doubling as axle stands. Really unsafe a lot of it.
On a serious note, what a lot of people don't know is that the cheaper jacks don't have an automatic bleed valve in them which means they need to be manually bled of air. Open the lowering screw and pump the handle slowly 5 or 6 times and it'll be fine. Pro quality jacks have the auto-bleed so don't need this Thumbs Up
Post #306008 18th Jan 2015 9:04am
Thanks but someone posted that on the previous page.
mzplcg wrote:
That jack probably only needs bleeding. Open the lowering valve fully, pump the handle up and down 5 times then re-test. The cheaper jacks don't have the auto-bleed thingy as I found out a while back. Thumbs Up
Post #306010 18th Jan 2015 9:07am
fisha
Alloys make good ramps too...
Very Happy V8 or else ...
Post #306943 21st Jan 2015 11:12pm
Page 2 of 3 <123>
