Home > Maintenance & Mods (L322) > Before you get under a car supported by a hydraulic jack...
Page 1 of 3 123>
This is the nose of my trailer supported by a 3500kg hydraulic trolley jack. There's less than 100kg on it.
This is a few hours later.
It's not an old jack. It was fairly cheap - think halfords quality. Maybe it has a fault, although it pumps up easily enough. Either way, you don't want your perfectly servicable jack developing a fault while it's supporting your Range Rover and you're underneath it.
Always use an axle stand if you're removing the wheels and going underneath the car.
Post #289618 29th Oct 2014 7:42pm
Sandyt
Wise words indeed Thumbs Up Thumbs Up Thumbs Up
Post #289621 29th Oct 2014 7:48pm
RiccartonRR
....and to add to the excellent words of wisdom!
If you ever take a wheel off store it under the car - beneath a jacking point. That way, if your jack / axle stands fail the wheel will take the load and reduce the severity of your injury. The added benefit is that using man-maths you can then justify buying those extra wide alloys you've had your eye on Thumbs Up Thumbs Up
Post #289626 29th Oct 2014 7:58pm
Mark L
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
I had an idea the other day...
Going to get a standard railway sleeper and get it cut into 4 pieces.
Then going to chainsaw cut a slope at the end of each one.
This will then give 4 mini ramps in which a vehicle can be driven upon.
If you don't require the raised height and simply wish to work on a corner with the wheel off, use aforementioned blocks to chuck under sills to act as insurance in case it slips off the axle stands.
Each block also has the potential to be modified to create a wheel chocking effect.
Post #289629 29th Oct 2014 8:11pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
@MarkL - Check out @Joe90 gallery - I think he beat you to it. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #289631 29th Oct 2014 8:17pm
Welshdragon
Im using my old pitch pine beams from the house decorating (renovation really Laughing ).....make great ramps Thumbs Up If it dont work.......burn it!
Post #289634 29th Oct 2014 8:21pm
Mark L
Struggling to find that one. Sounds interesting.
Have you a link to it at all, please?
Post #289638 29th Oct 2014 8:26pm
Here's Joe's thread.
Gives you an idea.
No good if you want to take the wheel off though. I personally feel there's nothing wrong with axle stands. They should never fail if they're in good condition and are correctly installed.
Post #289639 29th Oct 2014 8:27pm
Mark L
Top man - thank you.
Pretty much exactly as I visualised! Mr. Green
Post #289642 29th Oct 2014 8:32pm
mzplcg
That jack probably only needs bleeding. Open the lowering valve fully, pump the handle up and down 5 times then re-test. The cheaper jacks don't have the auto-bleed thingy as I found out a while back. Thumbs Up
Post #289649 29th Oct 2014 9:01pm
I just use a piece of 2x4.... works fine for me....
Rolling with laughter :rolllaugh:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #289651 29th Oct 2014 9:05pm
Welshdragon
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Like it Thumbs Up Thumbs Up Bow down
I have use the farm jack/hi-lift jack on the 90 challenge truck in a very similar way Thumbs Up Laughing If it dont work.......burn it!
Post #289653 29th Oct 2014 9:12pm
pld118
"I just use a piece of 2x4.... works fine for me.... "
In the name of the wee man! Shocked
I was going to post the other week asking for a poll as to who's comfortable getting under a car that's on axle stands. I've done it but am wary!
Post #289655 29th Oct 2014 9:20pm
miggit
Going under a car thats on axel stands is safe as houses, but like houses they need a good foundation, so make sure you are on concrete and that the car is sitting safely on the stands. When I lower the car on to stands, I leave the jack 1/2"" below the car and give it a dam good shake. That way if something has gone Pete Tong the car will jump back on to the jack and not hit the floor! Once I've given the car a good shaking and it hasn't moved, it is safe to approach!
Oh and when I say shake, I mean like you would a wee person who wont shut up, only you wont get arrested for shaking the car. So if your a frustrated parent... put your car on axel stands.... might help Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #289661 29th Oct 2014 9:49pm
Caught my neighbour throwing a cigarette butt onto my garden, so I lent him my jack.
Post #289877 30th Oct 2014 10:33pm
Page 1 of 3 123>
