![]() | Home > Technical (L322) > Key Start Up Issue |
If the battery that died is still in the car, that would my first point to check. Is it giving enough voltage to have everything work well. The other thing is, have you done the lock to lock with the steering wheel ??
OyabunG Member Since: 06 Jun 2012 Location: Perth Posts: 36 ![]() ![]() ![]() |
Hit the nail on the head |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Sounds as if the battery terminals might be corroded or you've a loose connection, might be worth a check before you go to the bank to get a mortgage extension to buy a new battery! Yesterday I couldn't spell Engineer... Today I are one!
His last post states, he replaced his battery and now all is well sir |
OK Craig, your obviously more awake than me today |
