Home > Technical (L322) > Key Start Up Issue |
If the battery that died is still in the car, that would my first point to check. Is it giving enough voltage to have everything work well. The other thing is, have you done the lock to lock with the steering wheel ??
27th Oct 2014 5:11am |
OyabunG Member Since: 06 Jun 2012 Location: Perth Posts: 36 |
Hit the nail on the head
30th Oct 2014 1:07am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
30th Oct 2014 3:30am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Sounds as if the battery terminals might be corroded or you've a loose connection, might be worth a check before you go to the bank to get a mortgage extension to buy a new battery! Yesterday I couldn't spell Engineer... Today I are one!
30th Oct 2014 10:42am |
His last post states, he replaced his battery and now all is well sir |
30th Oct 2014 10:45am |
OK Craig, your obviously more awake than me today Yesterday I couldn't spell Engineer... Today I are one!
30th Oct 2014 11:21am |
