![]() | Home > Technical (L322) > Headlight Wash+Wipe not working - quick fix needed for MOT |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Easiest solution is to remove both the wipers and spray nozzles. Then tape over the holes. Cleaning mechanism is then not fitted and can't be failed for not working. Can't be failed for not having the cleaning mechanism as the manual says 'may be fitted'. 56 TDV8 Vogue SE
