![]() | Home > Maintenance & Mods (L322) > If I drop 20mm with IID Tool do I need to do tracking |
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 ![]() ![]() ![]() |
Hi all, as above had a 4 wheel alignment done a few months ago but now got IID Tool, could do with dropping 20mm all round (easier access for arthritic wife) but don't fancy forking out for alignment again |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
Tracking should be advised when any suspension heights are altered, in either direction |
Still no wiser |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
1. Don't do it
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
I believe, from reading a subject a few weeks ago, that 2007-onwards models don't have a 'motorway mode'.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
In contrast to what Joe90 says
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
First question should surely be why have a 4x4 if you want something low to the ground?
If it is just getting in and out, why not use access height for that. I'm pretty sure you can lower access height a bit even if you wanted to without affecting the ride height at all. MY 2010 5.0 SC Galway green and sand interior!!
Post about 2005 the BCM wont accept different hight changes for different suspension settings so 20mm lower for standard height will mean 20mm lower for everything . 2008 MY Supercharged
Did you even read my original post ? ![]() @ ebajema If it is just getting in and out, why not use access height for that. I'm pretty sure you can lower access height a bit even if you wanted to without affecting the ride height at all. Not on a 2007 ![]() @ Mikey appreciate the feedback but according to dingg1 he has done it with no problems so still no wiser ![]() @ joe90 my book of words (page 190) says high "speed height" raises suspension 20mm if driven at over 100mph for over 5 seconds So appreciate all the replies but now have a load of conflicting information, so best bet is to buy wife a portable step and leave R/Rover alone ![]() |
Weigh up the cost of an alignment, versus the cost of 4 tyres |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
if you do drop it then just keep an eye on the tyre wear, if it starts going on the edges then put the height back to normal.. ... - .- -.
At that point though, it's too late.
