![]() | Home > Maintenance & Mods (L322) > If I drop 20mm with IID Tool do I need to do tracking |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
sorry , i disagree..... ... - .- -.
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 ![]() ![]() ![]() |
Found a solution |
stcstc31 Member Since: 01 Jul 2014 Location: dublin Posts: 209 ![]() ![]() ![]() |
another option
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Mine is lowered (as i run 22" wheels & it looks like its on stilts at standard ride hight)... Lowered using the IID tool... On my last three FF's i have lowered them without adverse tyre wear! I get the geometry checked when i fit new tyres anyhow |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
I have noticed on mine that the front lowers or appears to with continued over 100 mph driving I noticed the bonnet reference points had lowered - no faults showing |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
I dropped my 2002 model by 20mm using the IID tool over a year ago and can report no problems whatsoever, all tyres wearing evenly and very happy.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6770 ![]() ![]() ![]() |
I lowered my 2008 car by 20mm the day I got it, 2 1/2 years later, there's no sign of adverse tyre wear.
If you don't have enough tyre wear you obviously don't drive it hard enough guys |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
Does changing ride height using IID also alter the height when in Tight Tolerance Mode (as it has to be to set alignment, post-06MY)? |
Thanks to all for replies |
As far as I'm aware (and Patrick from GAP would be a better person to answer this) tight tolerance is set where the vehicle suspensions height is at time of setting... ![]() |
