![]() | Home > Maintenance & Mods (L322) > Fixed - HVAC Air quality sensor line fault |
You have probably worked this out for your self but that sensor will be for the automatic setting on the recirculation function , so its not the biggest of deals . Do you have it on the auto setting ? 2008 MY Supercharged
Axle, agree it's not a big deal. Just trying to know what bit is faulting. Will check the auto setting, thanks.
Well, since Axle's post I plugged the IID tool in using all different permutations of the Air Con, heaters, demisters and the seat warming/ cooling switched on. The fault remained and would not clear.
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
I had the same fault on mine - bought a new air quality sensor and that cured it.......literally just plugs in, easy fix |
Thanks CG-SC.
Looks familiar and is mounted behind the Land Rover logo in the grille |
Thats the external temperature sensor as stated . 2008 MY Supercharged
So is this the part CG SC meant? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35546 ![]() ![]() |
i think its this bit Ryan, [19E702]
Thanks Stan, I actually found that bit you refer to (I think!) this afternoon and wondered if that was 'it'. Will keep you posted.
It's the part that Stan correctly identified..... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
Thanks for confirming that CG |
Just worked out how you got that info Stan and can now - kind of - work Microcat. Very clever system.
