![]() | Home > Wheels & Tyres > Fitting wheels |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Wheel Hanger AKA Wheel Fitment Alignment tool ordered...£29 from the good ole' U S of A
quabba Member Since: 29 Aug 2014 Location: North Lanarkshire Posts: 39 ![]() ![]() ![]() |
I've ordered this
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
Yes, I saw lots of listings for that company but was not aware of the exact thread needed.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
i thought the same as these do look like male and not female as is required.. ... - .- -.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3258 ![]() ![]() ![]() |
Would welding rods onto a couple of spare wheel nuts not work just as well? John
you'd have to grind your nuts down so that the wheel hole will fit.. ... - .- -.
Yes, whatever is on the hub side would have to pass back through the hole in the wheel, or you'd never get it off without taking the wheel off again after you've aligned it.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
https://www.spaldingfasteners.co.uk/catego...agon-bolts
I might be missing something here then.....
the FF has studs coming out of the hub so no bolt type thingy will work.. ... - .- -.
I got the ones shown in the YouTube video from the manufacturer but via eBay ( item code eBay Item No. 400776075158) GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
That's the proper tool.
I'll post the specs when they arrives so that you engineering boys can have a fettle on your home lathes |
If I'm reading this right, I'm getting a pair of the ones PM2 has ordered for £13 odd... To compliment my kneeling mat |
