![]() | Home > Technical (L322) > Range rover l322 Air Suspension |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
try and put it in off road mode and listen for an air leak on that bag.. ... - .- -.
normalrangerover Member Since: 23 Mar 2014 Location: Sligo Posts: 21 ![]() ![]() |
I did try and I could not hear any air leak, and I lifted it up with a jack and it still made no sound, the air bag makes no attempt to move at all |
Its as if no air is going into the bag at all, its just staying flat all the time |
And the vehicle are suspension only fails our goes inactive when you move, Otherwise it will keep on working, It says for example is at standard height when clearly it is not, And if you raise it to off road height it just move a bit but keeps on flashing meaning it is rising but never finishes the job |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
Getting the fault codes read would be the first thing to do rather than just changing stuff... Pete
Articulation validity fault |
Either bag got a hole or height sensor is broken. Worst case valve block / solenoids packed up.
I can hear the pump running if that makes any difference, and the vehicle does move on the other air bags just very slowly |
You've not done your profile (please do it) so we don't know the age of your car. This could also point to a worn out compressor on an older vehicle? There are so many variables |
Apologies, we have many different type of Range rovers, but this one is an old 2003 range rover vogue 3.0 td6 |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
11 year-old airbag : give it a break and replace it, and the 3 others if you want to play it safe, I did |
It was the sensor, It had broke in half, Is there anyways to stick them back together without purchasing a new one? |
Not really, it's plastic into a metal rod.... but you can bodge it.... |
Could be the solution I need |
