Home > Maintenance & Mods (L322) > Internal windscreen pillar trim
supershuttle
Is it easy to remove this, if so how?
I need to run a cable to the top of the dashboard from the glovebox or is there a better way to get a cable from the glovebox to the top of the dash.
Thanks for any help Thumbs Up Geoff
Post #287168 17th Oct 2014 6:49pm
Would it be easier to take the top off the dash to get from glove box to dash top. Sure I've seen a powerful vid for this and it looks like the top screws off and slides forwards. There is nothing that can't be fixed with a hammer😜😜
Post #287172 17th Oct 2014 7:25pm
mjdronfield
Depending on where / how you want to route it, you could ease up the speaker grille and unscrew the speaker, in the dash. Could give you some access to the central area if it helps.
The dash end caps with vents can be removed also, if that helps you..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #287181 17th Oct 2014 8:24pm
supershuttle
I can never figure out how to get the grills off/out. Geoff
Post #287182 17th Oct 2014 8:27pm
Googsy
Which Grilles dash top or air vents ? I have had my dash off more times than a strippers brassiere so ask away Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #287206 17th Oct 2014 10:05pm
the pillar just pulls off Geoff, bit of a sod to get back though.. ... - .- -.
Post #287207 17th Oct 2014 10:06pm
supershuttle
Conor,
Its the side vents, I only want to get a cable from the glovebox to the top of the dash without going over the top of the wood trim, which means going under or behind it. Geoff
Post #287218 17th Oct 2014 10:34pm
supershuttle
Right I know its a crap picture but it shows the vent and you can also see the wire I am trying to hide - any ideas
 Geoff
Post #287221 17th Oct 2014 10:46pm
Remove the plastic Airbag badge at the top (just prize it off) then you will find a torx 40? screw. Remove that and then the pillar just pulls off sir Thumbs Up
Why are you trying to get a wire up to the top? If you need power? The vanity mirror light power is ignition controller sir Whistle Thumbs Up
Post #287222 17th Oct 2014 11:06pm
supershuttle
Thanks Craig,
It's not up to the top where the vanity lights are, I have a dash top mounted Road Angel (came with the car) and someone has already wired the other end into the glovebox and routed it over that corner, I just want to hide it so behind the bottom of the windscreen side trim is one option. Geoff
Post #287223 17th Oct 2014 11:27pm
MachineHead
Scotland 2009 Range Rover Westminster TDV8 Mariana Black
On mine if you remove the Landover badge on the pillar there is a single screw behind it, then it pulls off.
Edit - doh just noticed I was beaten to it - cancel Embarassed 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #287320 18th Oct 2014 2:07pm
supershuttle
Thanks all Thumbs Up Geoff
Post #287329 18th Oct 2014 3:14pm
