![]() | Home > Maintenance & Mods (L322) > Internal windscreen pillar trim |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3879 ![]() ![]() ![]() |
Is it easy to remove this, if so how?
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7878 ![]() ![]() ![]() |
Depending on where / how you want to route it, you could ease up the speaker grille and unscrew the speaker, in the dash. Could give you some access to the central area if it helps.
I can never figure out how to get the grills off/out. Geoff |
Which Grilles dash top or air vents ? I have had my dash off more times than a strippers brassiere so ask away |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35529 ![]() ![]() |
the pillar just pulls off Geoff, bit of a sod to get back though.. ... - .- -.
Conor,
Right I know its a crap picture but it shows the vent and you can also see the wire I am trying to hide - any ideas
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Remove the plastic Airbag badge at the top (just prize it off) then you will find a torx 40? screw. Remove that and then the pillar just pulls off sir |
Thanks Craig,
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 ![]() ![]() ![]() |
On mine if you remove the Landover badge on the pillar there is a single screw behind it, then it pulls off.
Thanks all |
